I'm using the Brume 2 as my router, and using the Marble as the AP(In ap mode), so that all devices connected are being filtered by Brume 2, I want to set up vlans so I can exclude some IOT devices from the larger part of my network but I can't really understand how to tag the vlans in on the switches panel on luci on the marble, I asked the AI for a guide but it's not really familiar with the version of LUCI the marble has on it, so I am trying my luck here, thanks in advance to anyone who might attempt to help me out here. Ideally I'd like a reliable guide on how to set up two vlans, one for existing network, and one for everything I would like cordoned off.
I have the AR750S Slate router which has the Switch0 VLAN configuration page (swconfig) which is different than my newer Brume 2 and Flint 2 routers which use the Bridge VLAN Filtering page (DSA). I found the following page helpful for me because it shows the differences when configuring VLAN’s on swconfig and DSA devices.
Thank you so much I will give this a try.
