Brume 2 routing tailscale traffic to exit node
Has anyone got this to work? Not using it itself as an exit node but to route the traffic going through it to an exit node? thanks
Yes but only kind of, I can’t access some google services and some other sites. It does show that my traffic is going through the exit node though. I tried with the windows and android clients and I do not have the same issue so I’m guessing it is something on the Brume 2.
