Brume 2 Setup failed - Help required
Brume 2 - i bought this week, i am failed to setup.
i am using Flint 2 at my another end (home2). i want access my (home1-Brume2) internet access.
i configured as per Glinet video guide. its connecting, but cant access internet.
home 1 ISP Router - 192.168.1.254
Connected Brume2- Lan IP 192.168.8.1
Wan IP- 192.168.1.111 (connected to Lan ISP Router)
Port used wire-guard Server >>> 51363
client IP 10.0.0.2/24
Port Forwarded 192.168.1.111 >> 51363 in ISP Router
My flint 2 IP : 192.168.1.1
i tried from Flint2 as a wire-guard Client - Connected - No internet
i tried from Android mobile as a wire-guard Client - Connected - No internet
Where i am make mistake, pls guide
Any other best method pls suggest.
Thanks in Advanced.
To help us analyze the issue more effectively, please:
  1. Provide a network topology diagram illustrating how your devices are connected and their IP addresses.
  2. Share screenshots of both the Brume 2 (WireGuard Server) and Flint 2 (WireGuard Client) configuration pages.
If feasible, connect both devices to GoodCloud and share the setup with us as described in the tutorial below:
This will enable us to remotely review and correct any configuration problems for you.
Hi Will.qui,
I already technical shared cloud access to my devices.
ISP ROUTER (192.168.1.254) >>> BRUME 2 (192.168.1.111- static stetted in ISP Router) >>>> wireguard server - 10.1.0.1/24 Port -51820.
ISP Router Port already opened 51820 - UDP
[Interface] Address = 10.1.0.2/24 PrivateKey = XXXXXXXXXXXXXXXXXXXXXXX= DNS = 10.1.0.1,64.6.64.6 MTU = 1420 [Peer] AllowedIPs = 0.0.0.0/0,::/0 Endpoint = 121.1xx.xx.xxx:51820 PersistentKeepalive = 25 PublicKey = XXXXXXXXXXXXXXXXXXXXXXX
As discussed via PM, your ISP currently provides a private IPv4 address (CGNAT) instead of a public IPv4, which prevents Brume 2 from accepting incoming VPN connections.
After attempting to switch to IPv6, everything is working properly.
But please note that the WireGuard client must also have IPv6 connectivity for the VPN to work.
Please contact your ISP to confirm whether a public IPv4 address can be provided for more versatile usage.
If you decide to reconfigure the VPN in the future, the following guide outlines useful troubleshooting steps for WireGuard:
How to Troubleshoot WireGuard
Hi Will.qui,
I already got Public IP, pls check and Setup. i already tried can’t. i send PM full details.
