Hi, am really not sure about the general product features because its seems that majority is same as Slate AX and Flint as well.
The only way that am confused about this product is SD-WAN instead of WAN and configuration as well since there is no wifi availability.
Let’s say the product am connect directly to my isp modem which is PPPOE protocol, then my 2nd router is connected to Brume 2, did my 2nd router will also get PPPOE protocol or DHCP?
This is what i need to clarify of the configuration.
