I know this has been topic here before but it was closed about a year ago.
My question, is there a USB WIFI stick available for the Brume 2 that works reliably 100%, I am asking this for a good reason, my friend want a VPN on his TV, but, there’s no cable behind his TV, connected through WIFI now, so I want to connect wirelessly and then use a LAN cable in between the Brune 2 and the TV.
We have not conducted official compatibility testing with USB Wi-Fi adapters, so we are unable to recommend or guarantee support for them.
If possible, you may consider adjusting your network setup.
For example, you can configure your existing Wi-Fi router to AP Mode and connect it to the LAN port of the Brume 2 to provide wireless coverage.
