Brume 3 as the spoke client?
Hello
Since the Brume 3 is superior in every way except wifi to the Beryl 7 can I create a GoodPAS tunnel between two Brume 3s ? Gemini says no. The Brume 3 can only be an AT HOME exit node and cant be a spoke client. Is that true?
The latest firmware for Brume 3 (GL-MT5000), v4.9.0, supports AstroWarp. You can configure one Brume 3 as the home exit node and another as the remote client, using “Use At Home” and “Use While Travelling” respectively.
For detailed setup instructions, please refer to our AstroWarp guide.
