I have the Brume gateway which I placed behind my Cable Modem router and then connected the Brume forward to my Google Nest Wifi.
However, I tried to use the VPN Policy to exclude certain websites but it doesn’t work. I guess it is because in my gateway, I only have 1 device (the Google Nest Router) and for some reason it doesn’t capture the websites or domains I try to exclude? Is there any workaround or fix for this? I have my Nest Wifi configured for use with Cloudfare DNS; as well as the GL inet.
See pic attached;
Thanks!
