Brume is discountinued, wont get 4.x firmware, correct?
hi,
i know everything is about money.
just ask as i just want to know.
as i saw opal got 4.x firmware,
but brume still only 3.216.
so brume will stay there is it?
ps: in that case as brume is supported by openwrt, i’ll suggest installing that on brume.
thanks
in the download center, there is a 4.3.8 available for Brume in beta:
https://dl.gl-inet.com/router/mv1000/
GL.iNet ran into an issue with v4 that the Brume W was being turned into a Brume, so the wireless stopped working.
That seems to have stopped v4 for the Brume, although the beta runs fine.
