Please help with the physical setup and configuration to use the Brume as a vpn gateway for my home network.
I want to use it purely to route all my home network traffic over my PIA vpn and would prefer not to create a new subnet on 192.168.8.1 and continue to use my Synology rt2600 connected to my fiber cable wan and DHCP.
Is this possible?
If it is can you please guide me through the setup process?
Eg do I connect an Ethernet cable from my Synology router LAN port to the Brume WAN or LAN port?
What Protocol setting to I use in the INTERNET settings of the Brume GUI admin panel - DHCP, Static or PPPoE?
What do I need to change in the settings of my primary Synology Router - port forward the WG client port, set Gateway to Brume IP, etc?
In this configuration, can I use the AdGuardHome on the Brume as a DNS adblocker?
Many thanks for your help - I’ve tried various ways and looked at lots of advice on the Internet but just can’t figure it out…
Thanks,
George
