Hi, I’d like to load vanilla openwrt since it’s EOL on the gl.inet side. Is there a link to the img?
And can I flash it via the GUI?
Here you go:
https://firmware-selector.openwrt.org/?version=21.02.3&target=mvebu%2Fcortexa53&id=glinet_gl-mv1000
Thanks bug
The regular v3.x won’t work on WAN. It won’t get an dhcp from my gateway. My Asus router does right away. Hoping a newer openwrt helps.
EXT4 or squash? Not sure which one to use or what the difference is? Just file system?
I think squashFS is easier ? (I don’t try out vanilla OpenWRT on my Brume yet)
After flashing vanilla OpenWRT image, how is going after that ?
I haven’t had time to flash you yet.
Hopefully soon. Thank you for following up.
you probably shouldnt keep settings going to 21 with BRUME as its changes to DSA from swconfig.
OpenWrt 21.02.0 first release candidate - Release and security announcements - OpenWrt Forum
My hero. I will try that method soon.
Do you have all 8gb emmc?
No, I don’t see the 8GB space by default and I am not satisfied with the default mounting space allocation layout.either.
I am still trying figure out if there any method to change this.
Sorry I didn’t try. How much space do you have now?
