can we make a guest interface on the switch so as to integrate with other 3.x features?
I have tried other low power legacy wireless adapters and power seems to be an issue. gl-usb150 is the only thing working with it without any discovered issues.
I did some thermal tests and it seems to just sit at 46 C. what throttling occurs at this point?
I have owned the AWUS036AC adapter for 4+ years now and all i ever saw was it was alfa’s most powerful wifi adapter but it never had any good linux drivers. I guess that has changed. can you pm a link for the firmware or is it one that is there already in downloads?
okay I see in the interface you can switch between 2.4ghz and 5ghz so only one can be active at any given time. makes sense from a usb power perspective.
