There is NO “empty list”.
You cannot exclude nothing. It has to be All or Something.
If you want to exclude NOTHING, think our include ALL.
Just want to say in everyday language,
exclude (empty list) = exclude nothing. exclude ALL = really exclude ALL.
The brume may behave like what you say (exclude empty list also = exclude ALL) for some reason,
may be this is easier for programming etc.
but certainly, layman will think as the everyday language i mentioned above,
as agreed by another user.
thanks
I do agree with you.
Now the UI is designed by Engineers, not product managers. We need better design to make it work for consumers. We will develop this on smartphone app.
Been a little while, but I have re-visited this and done some further testing.
My conclusion is that I wholly concur with posts 1 and 3:
The VPN policy is flawed in that if you set “Use VPN for all processes on the router” and click apply with an empty exclusion list (ie. everything is included) it does the complete opposite to what it says. ie. ALL traffic is excluded and uses ISP.
Regarding the Kill-Switch - this also fails as it is over-riden in the above scenario (ie. use VPN for all processes and set an empty exclude list).
I would kindly ask that these serious leak issues are addressed ASAP!
From your screenshot, it is clearly that, you exclude all for vpn, i.e. do not use vpn for all.
You’re joking right? I have “VPN for all processes” enabled and nothing in the “do not use VPN for” list!
To me, (and the OP, for that matter) both those settings mean use VPN for everything!
This should be the default situation (where 11:11:11:11:11:11 is a made up MAC)
If you do not add any item in the list, it means “do not use vpn for the following” → all Mac addresses
There is “Do (not) use vpn for all Mac address” logic
There is no “Do (not) use vpn for empty list” logic.
OK, having had a much closer look, I see what is happening here now - I see you have added the words “all MAC address” if you click apply with an empty list (I think this was added in 3.105 which I am testing currently). That clarifies things somewhat, although I would rather have had that in the drop down box to be selected and not pushed as the default.
we can always improve the UI. Pls use the current logic and UI for now. Thanks.
The problem is,
YOUR CURRENT logic is opposite to common sense.
This will make security-fans angry (I turn to openwrt for security over non-updated router).
Its better if you somehow told them BEFORE HAND (prevention) instead of they found out themselves
(screwed)<— this could lead to someone being persecuted, no matter you are in China, hong kong or USA.
It’s like you bought a metal safe, and you found out öops the safe could be open-ed this way.
try youtube “lock pickying lawyer”, you will know the frustration.
thanks
Suppose alzhao’s mom is asking him/her to list out things that will be DUMPED,
@alzhao want to dump nothing, and wrote “nil”, ëmpty" into the list and his/her mom dumped EVERYTHING he/she got instead (using his/her logic)
That’s when he/she will cry.
this is the common sense logic behind:
alzhao wrote nil into the list, and his/her mom will dump nothing.
this shd be the normal case for everyone.
btw even in 3.104 there are those words but one cant imagine they are included
Pls man, it is written there “everything”, not nothing.
I agree the logic is wrong - if you are applying VPN policies then it should be obvious that “all MAC address” is the last thing you are looking to do (otherwise you would turn off the VPN!).
I think the answer would be:
From what you said, the logic is correct. It is the UI not giving intuitive guide.
As I said, will improve.
