bug? Beryl AX - MT3000 v4.7.0 firewall not working
hello guys,
the mt3000 does not work in terms of firewall, not sure if it is something which started after 4.7.0
i have a simple setup with a tailscale exit node and custom firewall rules
the firewall hit counter increments but it blocks nothing
what is going on?
Update:
think already found it, after some digging , i was right, enabling tailscale makes its own chain (ts-input and ts-forward), when creating custom rules it overwrites all existing rules and thus bascially deleting tailcale chain, making tailscale non working, solution for me was for now adding the iptables via ssh to these chains, im sure after reboot they will be gone so really not stable for now
About which custom chains/rules are overwritten or deleted after the tailscale is enabled?
I will let R&D check if this is firmware bug or tailscale app bug.
enabling tailscale creates 2 chains
ts-input
ts-forward
Any firewall rule from luci has no effect because it adds them into the main input or forward table, making the tailscale chains basically evade them
That is why I added my rules into the tailscale chains themself via ssh (update: I might need to recall this as because I think even if the rules are in the main table during processing they still will hit the tailscale data as well, however about second note I’m sure)
The second note is that the option custom rules in luci, if you just save it or add whatever into it, it flushes out al the system generated firewall rules like the previously mentioned ts-input and ts-forward, thus causing tailscale to be non working (solution disable reenable Tailscale from GUI), but because of this you can’t have custom rules via luci, and need to tweak via ssh
When Luci manually adds rules, please use iptables -A -I eth0 -j ACCEPT, not -I
-A is added to the end of the chain
I couldn’t really follow you, is your syntax correct?
-I inserts at top which indeed would block them before they hit the tailscale chains
It’s more that saving anything under custom rules flushes system generated rules like the tailscale chains, causing black holing to happen
Sorry, iptables -A -I eth0 -j ACCEPT just gave an example, say perhaps using -A would be better.
May I know will the custom firewall rules (including the iptables -A) also cause tailscale chains (i.e. exit node) to be invalid?
