I would like to report a possible firmware compatibility issue on my Flint 2.
This may be related to the issue discussed here:
In that topic, a GL.iNet staff reply identifies FULLCONENAT rules being incorrectly included in the IPv6 firewall import. My case involves the same script, /etc/firewall.nat6, but a different rule: an IPv4 Docker rule containing 127.0.0.0/8.
I am not a networking specialist. The investigation and local workaround were prepared with ChatGPT’s assistance. I had no noticeable network problems before discovering the log error.
System
Router: Flint 2 / GL-MT6000
GL.iNet firmware: 4.11.0
OpenWrt: 21.02-SNAPSHOT, r15812+1095-46b6ee7ffc
Kernel: 5.4.238
IPv6: enabled, native mode
IPv4 Docker rules are present on the router
Observed error
When the firewall reloads, /etc/firewall.nat6 produces:
ip6tables-restore v1.8.7 (legacy): host/network `127.0.0.0' not found
Error occurred at line: 63
The script’s nat6_init() function contains:
iptables-save -t nat \
| sed -e "/\s[DS]NAT\s/d;/\sMASQUERADE\s/d;/\sMASQUERADE$/d;/\sFULLCONENAT$/d;/skip firewall.nat6/d" \
| ip6tables-restore -w -T nat
The FULLCONENAT exclusion is therefore already present in my firmware. However, the filtered output still includes this IPv4 Docker rule at line 63:
-A OUTPUT ! -d 127.0.0.0/8 -m addrtype --dst-type LOCAL -j DOCKER
This causes the IPv6 import to fail.
Local workaround tested
An additional filter was inserted immediately before ip6tables-restore:
| sed '/DOCKER/d' \
The modified input passed ip6tables-restore --test. After executing the modified script:
The script completed without the previous error.
The expected LAN/WAN IPv6 NAT hooks were present.
DNS redirection to AdGuard Home on port 3053 was present.
Previously duplicated rules in the IPv6 NAT table were no longer duplicated.
The original IPv4 Docker rules were not modified. Backups were made.
This is only a locally tested workaround, not a proposed universal fix. We have not performed comprehensive connectivity tests or established a user-visible improvement.
For completeness, the router also has a manually installed cloudflared service and modified AdGuard Home authentication. The firewall script has now been manually patched as described above.
Could you confirm whether this is another case of IPv4-specific rules being incorrectly copied into the IPv6 NAT table, and whether it can be addressed in the firmware?
Thank you.
