GL-RM10 (Comet Pro), firmware V1.10.0 release4 and V1.10.1 release2 — both affected.
ustreamer reports version 6.37 (GL build).
ustreamer leaks a file descriptor per FAILED snapshot, and kvmd never respawns it.
Repro:
- Leave the HDMI input with no signal (target powered off).
- Poll GET /api/streamer/snapshot repeatedly (any API client; ~1 req/6 s is enough).
- Watch ustreamer's fd count: ls /proc/$(pidof ustreamer)/fd | wc -l
Observed: ~2-3 fds leaked per failed request. They are UNIX sockets on
/run/kvmd/ustreamer.sock in state 03, held by ustreamer; kvmd correctly closes
its end (it stays at ~23 fds while ustreamer passes 600).
Snapshots taken WITH a live signal leak nothing — 20 consecutive HTTP 200s cost
0 fds on two separate units. The leak is on the failure path only.
At the 1024 soft limit:
kvmd.apps.kvmd.streamer INFO => [warn] Error from accept() call: Too many open files (x thousands)
kvmd.apps.kvmd.streamer DEBUG --- Terminating process pid=N
kvmd.apps.kvmd.streamer WARNING --- Process termination timed out after 3.0 seconds, sending SIGKILL
kvmd.apps.kvmd.streamer DEBUG --- Killing process group pgid=N
kvmd then NEVER restarts it. GET /api/streamer returns "streamer": null and every
snapshot returns 503 UnavailableError, with kvmd logging:
Can't connect to streamer: UnixClientConnectorError: Cannot connect to unix socket
/run/kvmd/ustreamer.sock [Connection refused]
All video stays dead until /etc/init.d/S98kvmd restart. HID, ssh and the rest of
the API are unaffected, so the unit looks healthy while video is gone.
Two separate asks:
- Close the accepted connection on the failure path in ustreamer.
- Have kvmd respawn the streamer after it kills it. Even with the leak, a working
respawn would make this self-healing instead of an outage.
Side effect worth noting: the accept() error storm floods syslog and wipes the ring
buffer, so all pre-failure history is lost — which makes this hard to diagnose after
the fact.
