I used the web interface in advanced mode to create three SSIDs on both 2.4GHz and 5GHz. In the Web interface, I selected ‘N’ and ‘AC’ options on the corresponding options.
In the /etc/config/wireless
file, “config wifi-device ‘wifi0’
” had hwmode
set to ‘11g
’, and ‘wifi1
’ was set to ‘11a
’. This obviously limited the bandwith available (checked by scanning using Acrylic Pro - 2.4GHz was advertising ‘b,g’ standards and 20 MHz channel width, for example).
Manually editing /etc/config/wireless
to change hwmode
to 11ng
for wifi0
and 11ac
for wifi1
corrected the wifi interface setup to provide 11n on 2.4 GHz and 11ac on 5GHz.
I know you don’t officially support folks using the full Luci web interface, but thought you should know, all the same.
