I realize if I update with a clean update I can’t connect to my private wireguard server using the config file
I have to update keeping the config files, and using the old client config of wireguard If I set up a new wireguard client using the config file it doesn’t connect I attach a screenshot that could help
This is the format of the config file that the wireguard of my raspberry provided me
PC1 is working, it’s the configuration that I kept when I upgrade
PC2 is not working, it’s the configuration that I imported after a clean upgrade
You can see that the format it’s different now I realize how to set up it properly if you want to detect and fix the bug ok, if you dont wan’t I don’t mind as I know how to set up it properly now, it’s your business and you manage it as you want
