From ssh I can not update packages or ping google.com (accessing GL-AR300 remotely via VPN. Is there any solution to get it working?
Thanks for any answer (I saw a similar topic in May 2022 but no answer found on the forum)
Currently I can only access remotely via the VPN (the device is far from my home) but everything seems to be OK as I have a device connected to the LAN port and this device can access Internet and send emails through the GL-AR300M.
My configuration is also OK with DNS set to 8.8.8.8
Ping to 8.8.8.8 is working ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 64 bytes from 8.8.8.8: seq=0 ttl=116 time=32.012 ms 64 bytes from 8.8.8.8: seq=1 ttl=116 time=42.346 ms
I found a solution by editing resolv.conf and adding manually nameserver 8.8.8.8
Apparently nameserver pointed to a wrong adress (192.168.1.1)
Thank you
