[Bug Report] Beryl 7 (GL-MT3600) — deleting MLO profile via UI removes UI entry but leaves orphaned wifi-iface sections broadcasting SSID
Product: GL.iNet Beryl 7 (GL-MT3600BE)
Chipset: MediaTek MT7993
Firmware: 4.9.0
Severity: Medium — no security impact, but leaves an undocumented, unmanaged SSID broadcasting after user believes it was removed
Summary:
After creating and then deleting an MLO Wi-Fi profile ("Beryl") via the web UI, the profile disappeared from the interface — but the SSID continued broadcasting on both 2.4GHz and 5GHz radios.
Root cause (confirmed via SSH/uci):
Deleting the MLO profile only removes the higher-level mld0 wrapper object and the UI's internal reference to it. It does not cascade-delete the underlying per-radio wifi-iface sections (wlanmld2g, wlanmld5g) that actually broadcast the SSID. These orphaned sections remained active in /etc/config/wireless and kept transmitting after the UI showed no trace of the network.
Steps to reproduce:
  1. Create an MLO Wi-Fi network (e.g. named "Beryl") spanning 2.4GHz + 5GHz via WIRELESS → MLO tab
  2. Delete the MLO profile via the UI
  3. Run uci show wireless | grep ssid via SSH — the SSID is still present in wlanmld2g/wlanmld5g sections along with the mld0 object
  4. Confirm via iwinfo — SSID is still actively broadcasting on-air, despite not being visible anywhere in the UI
Workaround:
Manual cleanup via SSH:
uci delete wireless.wlanmld2g
uci delete wireless.wlanmld5g
uci delete wireless.mld0
uci commit wireless
wifi reload
Suggested fix: UI delete action for MLO profiles should cascade-delete all associated per-band wifi-iface sections, not just the mld0 wrapper/internal reference.
Thank you for your feedback.
We have successfully reproduced the issue in our local environment and will ask our development team to investigate it further and implement a fix.
