Building for MIFI is broken, as it results in a clash:
Collected errors:
- check_data_file_clashes: Package wpad-mini wants to install file /etc/openwrt/openwrt_gli_MIFI/build_dir/target-mips_24kc_musl/root-ar71xx/usr/sbin/hostapd
But that file is already provided by package * wpad - check_data_file_clashes: Package wpad-mini wants to install file /etc/openwrt/openwrt_gli_MIFI/build_dir/target-mips_24kc_musl/root-ar71xx/usr/sbin/wpa_supplicant
But that file is already provided by package * wpad - check_data_file_clashes: Package wpad-mini wants to install file /etc/openwrt/openwrt_gli_MIFI/build_dir/target-mips_24kc_musl/root-ar71xx/usr/sbin/wpad
But that file is already provided by package * wpad - opkg_install_cmd: Cannot install package wpad-mini.
Using target MIFI, plus option “Select basic packages” in menuconfig.
Manually removing wpad-mini from selected packages fixes the issue. ALthough I do not need full wpad, wpad-mini would be suffcient. May be, use wpad-mini as default, instead of wpad ?
