OK. My mistake.
It is 192.168.0.198
OK. My mistake.
It is 192.168.0.198
Hi, Many thanks, I was thinking that is this one, but just to double check… ![]()
Hello, I have strictly followed your guide and successfully created a site to site wireguard vpn but now I wish to add a cell phone from where to see all the site lans. I have added the wireguard connection through the qr code but I can only access to the server lan: 10.0.0.1 and 192.168.8.1. If I try to connect to the first client whose nets are 192.168.10.1 and 10.0.0.2 I have not access by the cell phone.
Please help.
Walter
What is AllowedIPs in the phone configuration? You need to add both networks there (or use a full tunnel configuration).
Hello everyone. For firmware 4.X seems like there are some changes that prevent me from successfully accomplish this. Specifically:
/etc/init.d/wireguard_server , which prevents me from restarting WG/etc/config/wireguard_server file and rebooting, the wg output does not include the new CIDRwgserver instead of wgSome troubleshooting stuff I did:
find / -name wireguard_server
service --status-all
Thank you!
BTW I also tried to edit the interface with the LUCI GUI but it is the only interface that does not allows me to edit with a message that says “Unsupported protocol type”, even after installing luci-proto-wireguard
I give up, I simply cannot add the CIDR to the allowed IP list. Doing it on the config file with wg setconf file_name does not seem to work upon restart (wg output doesnt show the new CIDR)
Hello, for firmware 4.X, please refer to this post to set up S2S Building a Site-2-Site network manually using two GL.iNet routers(SDK 4.X)
