I did a fresh installation.
test@ubuntu:~/office-work/gl_imagebuilder$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
Used below command to install required packages.
sudo apt update && sudo apt upgrade -y
sudo apt install device-tree-compiler gawk gcc git g++ make ncurses-dev python unzip -y
Cloned the Imagebuilder to my system
git clone GitHub - gl-inet/imagebuilder: Warning!Please look at 'GL.iNET Imagebuilder Introduction' section. gl_imagebuilder
cd gl_imagebuilder
ran the following command
./gl_image -p ar300m -e “openssh-sftp-server nano htop”
and encountered the following probelm.
Configuring gl-sdk.
Configuring blkid.
Configuring gl-firewall.
Configuring kmod-GobiSerial.
Configuring lighttpd-mod-fastcgi.
Configuring kmod-crypto-sha1.
Configuring kmod-mppe.
Configuring kmod-GobiNet.
Configuring gl-ui.
Configuring ppp-mod-pppoe.
Configuring dnsmasq-full.
Collected errors:
- opkg_install_cmd: Cannot install package gl-crond.
Makefile:149: recipe for target ‘package_install’ failed
make[2]: *** [package_install] Error 255
Makefile:108: recipe for target ‘_call_image’ failed
make[1]: *** [_call_image] Error 2
Makefile:192: recipe for target ‘image’ failed
make: *** [image] Error 2
Failed to build GL-AR300M…
Probably, something needs to be fixed in installation instructions.
