I’d like to be able to use the side switch to enable/disable the Force VPN (No internet if VPN is not connected) option.
Certain wifi hotspots require re-auth through their captive portal. It would be good if I can just slide the switch, re-auth to wifi, then turn on the force vpn back on so that if the tunnel goes down, so does internet.
I saw the various threads on Button scripts - but if i understand correctly, the default behavior is to output to console. I have tried that, but do not see anything on console.
Just to be clear - if I login and do nothing, slide switch left or right, I should see some message directly on:
root@T3000:~#
OR do I need to look somewhere/run something to monitor the output?
