I have a GL-E750 and I want to change the configuration of the Button that I can switch between 2 VPN profiles, is this possible? what do I need to change?
If not it would be great when you can include this in the next firmware.
Maybe there can be a option that you can set a VPN Profile on button down and another one in Button up
this would be great, thank you
It will be too difficult. When adding a new script, it may break other functions and too much to consider.
Can you use the smartphone app to change vpn profiles?
