Bypassing Tailscale on VPN Client
My current GL-iNet router has the VPN Client ON.
One of the devices connected to it has the Tailscale ON
Is there an way to bypass only the Tailscale traffic from the VPN?
Thanks
Try the VPN Policy mode:
VPN Policy Based on the Client Device with Do Not Use VPN, select that special device which running the tailscale.
But in this case, all traffic will bypass the VPN.
I would like only Tailscale traffic to bypass the VPN
Oh, I see.
However, the router cannot recognize the data packet/traffic of Tailscale, and the Tailscale traffic of the client is not a specific IP or domain name, which seems to be unable to achieve.
And the Tailscale interface is not on the router.
Truly sorry.
Found a solution, adding their subnet addresses 100.64.0.0/10 as a rule to not use VPN.
