Can Beryl AX (GL-MT3000) support the new U-NII-4 band(band 169-185 5.850–5.925 GHz)?
If now it doesn’t support,can it be added in the future by upgrading firmware?
In other words,is the Beryl AX (GL-MT3000)'s hardware support U-NII-4 band?
I mean if the hardware supports it,perhaps the U-NII-4 band can unlocked by upgrading firmware in the future.If the hardware does not support,there are no way to support that.
I want to know the truth.Thank you!
