I have been using GL-AR300M router as an intermediate router to combine 2 internet connections using mwan3 package. The LAN port on router is configured as another WAN port and I’m using an USB Ethernet adapter to connect between GL router and gigabit wireless router, which distributes the internet over WiFi.
This setup is working great, and I’m getting full 75Mbps with 2 internet connections of speeds 50Mbps and 25Mbps while using multiple connections.
With advent of cheap internet, now both ISPs are offering 100Mbps plans for lot less. My question is, if I replace the current 10/100 USB Ethernet adapter with Gigabit Ethernet Adapter, will I be able to tap in higher speeds (as my WiFi router is already gigabit). I had read USB 2.0 port is able to deliver 400Mbps of bandwidth theoretically, so 150-160Mbps should be pretty doable right?
Or is this 100mbps limitation is coming from router chip-set, and the gigabit USB Ethernet will still be stuck at 100mbps?
