Can I successfully run the GL-Tor package on the GL-AR750 ? I know the space is limited but if I add a 100 GB micro SD will that be able to make space for packages on the router ? The mango doesn’t have enough space to run tor I want to know if this will work before buying it. Thank you gl team and users
If you can use exroot, then you can do this on all routers.
We are planning to release a tor firmware directly so that you do not need to do this by yourself.
When do you plan on releasing it ?
Any guides on how to do it on extroot to get the tor firmware working ?
So I cant Just add a mirco sd for space
