Can I enable Wireguard VPN only for incoming connections
I have TorGuard and am having trouble accessing some sites through their WireGuard VPN so is there a way to make all outgoing connections from my network bypass the VPN rather than having to go and add each problem site as an exception (do not use vpn in policy)?
Thanks
Sorry, I didn’t understand what you meant. If you want all connections not to go through VPN, why not disable VPN?
I need incoming connections through the VPN ip (to access network servers).
Could you draw the topology and make it more detailed?
Should the network servers use vpn to access the Internet or not?
For vpn policy, you can try customized routing mode?
