Can I load balance with router in bridge mode?
I need to load balance 2 connections into a gl.inet router but I want the gl.inet router to operate in bridge mode.
Reason is both connections into the gl.inet router will need to do their own routing functions. Also I can’t turn off the routing part of the 2 connections.
As you have two routers, which router do you want GL.iNet router bridge to?
I don’t see it will work
