As the topic, can I use same SSID for both 5G and 2.4G on Convexa-B?
I have implemented this setting. The router did not reject the setting. Is there any potential problem with this?
This is recommend as it lets the client choose the frequency with the best signal. You shouldn’t see any issues unless the client connecting is very old.
Should be fine…
If you’re meshing convexa - one pretty much has to do that…
Just successfully meshed three nodes. Working prefect. Thank you, guys.
