Wondering if I can get a notification from my Flint2, when the internet connection is lost?
Not sure how?? Through the app, when I'm onsite?
And can it create/add to a log 'somewhere' to keep a record of same.
You can use GoodCloud to receive email alerts when your Flint 2 goes offline or comes back online.
After binding your router to GoodCloud, go to Notifications → Add Rule, select your device, and configure the online/offline notification rule following this guide.
The router also records connection events, such as Ethernet link loss and Wi-Fi repeater disconnections, in its logs. You can review these under SYSTEM → Log in the router’s web admin panel; see the log guide for details.
What should clients from Russia do? GoodCloud is blocked in Russia and does not work at all.
I learned something new today, thanks @charles2 ![]()
Thanks!
What info is stored in "logs" in goodcloud? Totally empty at the moment...
Does it only log info when you have setup alerts?
Thanks.
GoodCloud has several log categories, including Activity Logs, Device Logs, Upgrade Logs, Alert Logs, and Device Settings Logs; see this guide.
If you have only recently bound your router to GoodCloud, there may be few records available yet. Please also check the selected log category and adjust the date/time filter to include the period you want to review.
Unfortunately, notification functionality is currently provided primarily through GoodCloud.
If you have a working obfuscated VPN connection, you can try enabling “Services from GL.iNet Use VPN” in the VPN tunnel options, and click Apply.
This routes the router’s GoodCloud connection through the VPN and may help restore access to GoodCloud on your network.
