Bought a mango router as the idea of using it when I am not at home and having it automatically connect to my VPN was very appealling.
I am using PiVPN to run a wireguard service which is all running fine, however I can not figure out how to connect my Mango to my VPN - has anyone managed this?
You can generate a PiVPN Wireguard config file using the “add” command, then copy and load it on the router under Admin Panel → VPN → WireGuard Client:
