@madscientist_42
I think there is a problem of your repo.
What model are you using? AR300M? Are you in the nor firmware or Nand firmware?
Your logs shows that you are in the Nor firmware because the path is “ar71xx/2.26”. If you are using the Nand firmware the path should be “ar71xx_nand/2.26”. This should be set by the firmware itself.
If you download the firmware manually from testing folder, please redownload the firmware firm now.
Please let me know if there is anything wrong.
Here is my log
root@GL-AR300M:~# opkg install kmod-rtl8192cu
Installing kmod-rtl8192cu (3.18.27+2016-01-10-1) to root…
Downloading 404 Page not found - GL.iNet 2cu_3.18.27+2016-01-10-1_ar71xx.ipk.
Installing kmod-rtlwifi-usb (3.18.27+2016-01-10-1) to root…
Downloading 404 Page not found - GL.iNet i-usb_3.18.27+2016-01-10-1_ar71xx.ipk.
Installing kmod-rtlwifi (3.18.27+2016-01-10-1) to root…
Downloading 404 Page not found - GL.iNet i_3.18.27+2016-01-10-1_ar71xx.ipk.
Installing kmod-rtl8192c-common (3.18.27+2016-01-10-1) to root…
Downloading 404 Page not found - GL.iNet 2c-common_3.18.27+2016-01-10-1_ar71xx.ipk.
Installing rtl8192cu-firmware (2016-01-25-52442afee9907bc32a058f22bb3295d040677c 26-1) to root…
Downloading 404 Page not found - GL.iNet irmware_2016-01-25-52442afee9907bc32a058f22bb3295d040677c26-1_ar71xx.ipk.
Configuring kmod-rtlwifi.
Configuring rtl8192cu-firmware.
Configuring kmod-rtlwifi-usb.
Configuring kmod-rtl8192c-common.
Configuring kmod-rtl8192cu.
