Hi, I have an Opal router that I’m trying to setup with AzireVPN. I follow the setup guide as per AzireVPN Guide - GL.iNet
I enter my credentials, give it a name, then I recieve - Error: Add failed
There isn’t any other logs or info that I can see which might indicate why the add failed.
Login credentials are definitley correct. And I named it ‘azire’ no special characters.
Just to quickly update this, I downloaded the wireguard configuration files from the Azire website and applied the config manually on the Opal, this seems to have done the trick
@Parabol72 Hello . Did you also have problems with the browser when you entered the account number(AzireVPN) in the MUDI interface? Perhaps you have another device, I did not see its name in your message)).
I had the same problem but with a different provider. I’m interested to know your experience.
