Cannot connect to Brume 2 gui on home network
So I have my Brume 2 connected to my home network router via ethernet cable. I also have my home PC connected to my home network router via ethernet cable.
I want to access the Brume 2 GUI from my home PC. I tried simply entering 192.168.8.1 in my browser but it does not load. I looked on my home router to see if I could find some other IP address to try. It see one that starts with 45.30… but that doesn’t seem to do anything either.
How can I access the Brume 2 GUI on my home network? Thanks for any help.
Are you connected via WAN port or LAN port?
Just open on Firewall of Brume Port 80 or 443 (for https), use WAN port and you are good.
I’m connected to my home router via ethernet cable. The Brume is connected to my home router as well via ethernet from the WAN port
