cannot uart for AR300M Blank page
i tried on mac and on windows putty
the same
my ar300m is brick
any solution!
the same
my ar300m is brick
any solution!
what did you do to make it bicked? If you didn’t touch uboot, it will not brick.
One reason may be the usb uart adapter is not compatible. What is the model you are using?
i tired it with a working ar150m it didnt work too!
Works fine for me on OSX using minicom. Ensure you set speed to 115200!
any full tutorial ?
