Currently, I have two routers set up. The first router is provided by my ISP and the second router is a GL-AXT1800 router. I’ve connected the two routers using a LAN port on router 1 and the WAN port on router 2.
I’ve created a DMZ zone from the LAN port on router ISP to WAN port on router GL-AXT1800.
One of the GL-AXT1800 router’s LAN port is connected to a minipc with a Proxmox node with two VM, a Pi-hole and Nextcloud.
I can surf the internet from Wifi, Pi-hole does its job, I can configure the Wireguard’s VPN server and I arrive to the GL-AXT1800’s management web interface (192.168.3.x). However, I can’t reach the Pi-hole nor Nextcloud in the same subnet 192.168.3.x
What am I doing wrong? What am I missing?
Best regards!!
