I got my OpenVPN config files from RapidVPN I have the option to choose a UDP or TCP one and on multiple different ports, I upload my config file and it just keep on connecting and disconnecting to the VPN, should I post the config file here is it safe to do so? Any suggestions? I connect through PPTP on any device fine but I saw that MT300-V2 has this disabled on the lastest firmawares??? Why are options being limited? How can I proceed ?
You can post the config, removing the credentials and cert etc.
Also attached the openvpn log.
What do I need to remove from the openvpn log the IP address?
It worked, I talked to their customer support and its all good. worked like a charm no problem this morning.
