When i’m connected through GL-AR300M I cannot connect to any ssh server that’s not the router itself. Is there any rule that’s blocking this? If I try without GL-AR300M I can connect.
Thank you!
Thank you!
Where is the SSH server? Is it a server on the Internet or server in your local network?
The router doesn’t block any data outgoing, but only incoming.
