I bought the above product today and i have spent 4 hours trying to get it to work.
I have a Sky Q hub fibre and homeplugs from router to upstairs pc and smart tv. I followed the instructions on setting up but i could only connect to the mini router by wifi and could browse the web but not from pc or tv.
I had to use laptop wifi to do this.
I have tried to get to the setup page but i cant get the 192.168.8.1 to work.
I want to update the firmware and then put PIA vpn on it but i am struggling to connect.
I cant remember what i did but i got to the welcome page and selected English and then i went to flashing mode and after 20 mins or more it was still"flashing mode".
While this was happening it disconnected from LAN and then i turned the mini off and then restarted and all i got was choose English and then nothing happened after 20-25 mins.
I done the reset and then connected to the MT300n and the laptop as i can use the pc to check the forum.
It connected and i got as far as putiing in the openvpn files from PIA when i just kept getting error connecting or something like that.
I left it 15mins and when i came back it had disconnected from the MT300n and i couldn’t get any internet from it but on the pc it was ok.
I retried 3 more times and got the same result.
I can’t try the pc as it doesn’t have wifi and if i plug the cable into the mini router there and then to the pc there is no inernet as i use homeplugs which then connect to the homeplug downstairs next to the ISP router.
When i did connect it yesterday i noticed that i had 2 internet access 1 for my ISP SSID and 1 inidentified which turns out to be the TAP window adaptor V9 if that helps.
ISP’s router is working on wifi and lan/homeplugs.
I followed the instructions that came with mini router but was told to only connect pc to mini router.
I had to use a laptop and got connected and could use laptop wifi through mini router but i got to the setup page but when i put in the PIA OPVN zip i get the errors shown in the screenshot.
In the quick start Overview - GL.iNet Docs i do not have the DCHP listed and wifi is on, port 83 which has not open next to it.
I managed to get a bit further with the min router.
I have loaded the opvn files on to router and set it to switzerland.
Setup is laptop lan to mini router WAN. Can not connect to internet.
Managed to get DHCP up on settings page but will not connect to internet.
Took mini router downstairs to ISP router.
Pc to homeplug wall socket—downstairs homeplug from wall socket to WAN on mini-----cable from mini LAN to ISP LAN port. Nothing works and can get ISP router setup page or internet.
As i mentioned in 1st post i need to connect upstairs PC and tv through homeplugs going through the mini router.
I have inserted a screenshot of the latest setup if somebody could look at it and give me some advice please.
