Can't connect to WeWorkWiFi?
Using AXT1800. Can’t connect to WeWorkWiFi anymore. The network does not show up in repeater mode scan. The network appears on other devices and works fine.
Did you change something during the last time?
Is “allowing DFS” enabled in repeater config?
You could check the country code in luci as well, might be a problem.
Enabling “allowing DFS” worked. Thank you!
Just curious, why did that solve the issue?
It seems like the WeWorkWiFi uses now channels within the DFS range.
Maybe they upgraded the router or use the 160 MHz band now.
