can't log in to GL-RM1PE
just received my rm1pe and for the life of me i can’t get access to the glkvm.local
it’s currently plugged into the same network on a poe switch with white led blinking.. i attempted the GLKVM app which detects it under find device, but then when you attempt to bind it, it says binding failed..
any advice would be appreciated..
White led blinking means the RM1PE has no Internet access, Could you please check the network source works fine and other devices can get Internet from it?
it’s so random, it’s been plugged into the same network port and poe switch for about 3 days and been doing the same thing, this morning i looked at it and it was solid white, tried glkvm.local and it work then tried binding it to the app and it worked instantaneously.. so weird.. but glad nonetheless..
thanks..
