Ive disabled dhcp on the router. But adguard wont let me use dhcp. It gives the following error:
In order to use DHCP server a static IP address must be set. AdGuard Home failed to determine if this network interface is configured using a static IP address. Please set a static IP address manually.
After disabled the router DHCP server, first set a static IP for the PC network card to continue to access the router, and then access AdGuard Home DHCP settings, fill in the information of the DHCP server, and click save configuration.
Clicking Check for DHCP server may also have the same prompt, but you can click Enable DHCP server at this time, and then change the PC network card to DHCP mode. Other clients can also obtain DHCP normally.
