Yara
April 6, 2022, 8:17am
I tried to search for this on the forum but seems like I couldnt find anything.
I wanted to know whether its possible to CHOOSE the cell tower the Mifi/3G4G Router is connected to. I know you can see the towers under cells info, but I couldnt find the place to actually choose. I checked under LuCi as well.
Any advice would be appreciated.
alzhao
April 6, 2022, 8:45am
2
Sorry I don’t know the answer.
Yara
April 6, 2022, 9:05am
3
Hi Alzhao, thanks for replying to me.
Surely you know whether there is a feature that you can choose cells? Did you code in this feature? Does one have to manually code it in?
alzhao
April 6, 2022, 10:23am
4
It is the modem’s choice to choose which tower.
So we don’t code about this.
But one direction is to use AT command to ask the modem to choose tower. But I don’t know which command.
Yara
April 6, 2022, 10:47am
5
AT Command varies on the type of modem we have. What is the type of modem that is used in Mifi?
Thorough another forum, I found an article a command in the following document, page 347, AT^CELLLOCK
at least for the ME909s Series.
But this doesn’t work on the Mifi.
alzhao
April 7, 2022, 9:47am
6
You need to find this info from the router’s admin panel. It displays the modem model.
