Could you please tell me the domain name you use to apply for certificates on Cloudflare.
For example, if you use abc.com to apply and add the .crt and .key in /etc/kvmd/user/ssl.
It can only works when accessing KVM using abc.com. It is ineffective to use an IP address or any other domain name.
So, I have tried with a wildcard and specific cert.
so to take your example abc.com. If I create a wildcard or specific cert to kvm.abc.com I will get a browser error asking for override as it can not confirm the issuer.
I am aware that if I used a DNS rewrite to a different name or the IP address it would ask me to override as it does not match the cert name
