certificate issue with https Web UI (GL-MT3000 Beryl AX)
I just got my GL-MT3000. Setup is ok, except for the certificate issue when I launch https://192/168.8.1/. Tried to replace the certificate below with my own self signed openssl certification, but doesn’t work. Please let me know what I should do to fix this issue.
/etc/nginx/nginx.cer
/etc/nginx/nginx.key
Does your system trust the self-sign CA for your self-sign-cert? Did you included the certificate chain and restarted nginx + cleared browser cache?
Certs usually work only for DNS names, so IP will still throw errors
When I checked the certificate in my browser, somehow I still saw the older certificate. I did cleared the browser cache, it didn’t work.
I don’t have that much knowledge on this. Can you provide the step by step instruction so that I can try?
There is no need for replacing it anyway, so why do you want to replace it? If you don’t have the knowledge you shouldn’t do it :wink:
Googling „nginx ssl self-signed“ should lead to the steps you need to follow.
Thanks for your advice.
BTW, if I accept the risk and continue, does that means that the communication will be encrypted or will be plain text.
I will do some googling for sure.
Connection is still encrypted.
TLS itself (https) will ensure the security, a trusted (!) certificate will ensure the … well … trust.
Replacing an untrusted cert by another untrusted cert isn’t that useful.
Good to know.
Let me do some research. I might try Let’s Encrypt later.
This might help you for studying:
