Change email address for notification
Is it possible to change email address for alerts/notifications?
For now I can use only my login email.
I would like to use for example PagerDuty integration via email.
Currently, the cloud platform does not support setting an email address for alerts/notifications other than the login email.
However, this is a great suggestion. We are already optimizing the alerting feature and will consider allowing the option to set additional email addresses for receiving alerts
