Change log for beta/snapshots
Is there a change log somewhere? I would like to know differences between FW 4.2.3 and FW 4.3.2 and of course would love to have that info updated with every beta/snapshot push.
That would be more useful for the dev team as well as we could focus testing fixes/changes.
Thank you!
Yes, there is and you can access it based on your device model and the firmware version: http://download.gl-inet.com/firmware/
For example, for my device: http://download.gl-inet.com.s3.amazonaws.com/firmware/x3000/release/metadata_4.3.5
You can click “Release Note” in GL.iNet download center (gl-inet.com).
Thanks for sharing this! I did it the long way :upside_down_face:
My question was specifically about 4.3.2 vs 4.2.3.
While there is such information for the for AXT1800 4.2.3 beta here:
https://dl.gl-inet.com/?model=axt1800&type=beta
There is none for AXT1800 4.3.2 snapshot here:
https://dl.gl-inet.com/?model=axt1800&type=snapshot
It would be nice to have change logs for the snapshots as well.
Maybe there is a git repository where we could follow latest commits?
Thank you both!
Snapshot version not available for logging …
First of all, it is compiled automatically.
Second, it may be intended to fix a bug, but many snapshots may fix unsuccessfully or even create more bugs. that’s why it needs to be tested.
Finally, we will most likely not release a stable version of the corresponding snapshot.
