I am using GL-MT300N-V2 in Glinet WDS mode.
The Mango acts as a WIFI bridge to connect wired LAN devices.
Main router ->> WIFI → GL-MT300N-V2 → LAN device.
WIFI access point is switched off as I only want to connect wired devices.
I am happy with the setup and it works perfect for the one connected LAN device, but now I need to add a second LAN device.
I thought I could avoid using a switch when it would be possible to change the unused WAN port to act as a second LAN port.
Luci is installed and I am confident to change a config file if needed.
I want to keep the WDS preset config and just change a small bit.
If I need to setup the GL-MT300N-V2 as a Wifi bridge from scratch in Luci like in times when Glinet had no WDS preset, I will prefer to add a switch.
Any idea?
